How to plot data at observation points#
timesteps. Since requested observation points don’t necessarily coincide with
ogstools.meshlib.mesh_series.MeshSeries.probe for more details.
from ogstools import examples, meshplotlib
from ogstools.meshplotlib.utils import justified_labels
meshplotlib.setup.reset()
si = Scalar(
Let’s define 4 observation points and plot them on the mesh.
points = np.asarray(
[[x, 0, 60] for x in [0, 40, 80, 120]]
+ [[x, 0, 40] for x in [0, 40, 80, 120]]
fig = meshplotlib.plot(mesh_series.read(0), si)
fig.axes[0].scatter(points[:, 0], points[:, 2], s=50, fc="none", ec="r", lw=3)
for i, point in enumerate(points):
fig.axes[0].annotate(str(i), (point[0], point[2] - 5), va="top")
plt.rcdefaults()
And now probe the points and the values over time:
labels = [f"{i}: {label}" for i, label in enumerate(justified_labels(points))]
fig = meshplotlib.plot_probe(
mesh_series=mesh_series, points=points[:4], mesh_property=si,
time_unit="a", labels=labels[:4]
You can also pass create your own matplotlib figure and pass the axes object. Additionally, you can pass any keyword arguments which are known by matplotlibs plot function to further customize the curves. In this case marker and linewidth are not part of the API of plot_probe but get processed correctly anyway.
fig, axs = plt.subplots(nrows=2, figsize=[10, 5])
mesh_series, points[:4], si, time_unit="a", ax=axs[0], colors=["k"],
labels=labels[:4], marker=".")
mesh_series, points[4:], si, time_unit="a", ax=axs[1], linestyles=["-"],
labels=labels[4:], linewidth=1,
Total running time of the script: (0 minutes 1.352 seconds)
