Workflow: Component-transport model - conversion, simulation, postprocessing#
In this example we show how a simple mass transport FEFLOW model can be converted to a pyvista.UnstructuredGrid and then be simulated in OGS with the component transport process.
Necessary imports
import tempfile
) # fmt: skip
# values of 0.
ot.plot.contourf(clipped_mesh, concentration)
<Figure size 1099.71x1080 with 2 Axes>
Setup a prj-file to run a OGS-simulation.
time_steps = list(
feflow_model.save()
<OpenGeoSysProject>
<meshes>
<mesh>2D_CT_model.vtu</mesh>
<mesh>single_species_P_BC_MASS.vtu</mesh>
</meshes>
<processes>
<process>
<name>CT</name>
<secondary_variables>
</secondary_variables>
<process_variables>
<pressure>HEAD_OGS</pressure>
<concentration>single_species</concentration>
</process_variables>
</process>
</processes>
<media>
<medium id="0">
<phases>
<phase>
<type>AqueousLiquid</type>
<properties>
<property>
<name>viscosity</name>
<type>Constant</type>
<value>1</value>
</property>
<property>
<name>density</name>
<value>1</value>
</property>
</properties>
<components>
<component>
<name>single_species</name>
<properties>
<property>
<name>decay_rate</name>
<value>0.0</value>
</property>
<property>
<name>pore_diffusion</name>
<value>3.5999998241701783e-10</value>
</property>
<property>
<value>16441.72737282367</value>
</property>
</properties>
</component>
</components>
</phase>
</phases>
<properties>
<property>
<name>porosity</name>
<value>0.10999999940395355</value>
</property>
<property>
<name>longitudinal_dispersivity</name>
<value>0.0</value>
</property>
<property>
<name>transversal_dispersivity</name>
<value>0.0</value>
</property>
<property>
<name>permeability</name>
</property>
</properties>
</medium>
</media>
<time_loop>
<processes>
<process ref="CT">
<convergence_criterion>
<type>DeltaX</type>
<norm_type>NORM2</norm_type>
<reltol>1e-6</reltol>
</convergence_criterion>
<time_discretization>
<type>BackwardEuler</type>
</time_discretization>
<time_stepping>
<t_initial>0</t_initial>
<t_end>48384000</t_end>
<timesteps>
<pair>
<repeat>10</repeat>
<delta_t>8.64</delta_t>
</pair>
<pair>
<repeat>10</repeat>
<delta_t>86.4</delta_t>
</pair>
<pair>
<repeat>10</repeat>
<delta_t>864.0</delta_t>
</pair>
<pair>
<repeat>10</repeat>
<delta_t>8640.0</delta_t>
</pair>
<pair>
<repeat>10</repeat>
<delta_t>86400.0</delta_t>
</pair>
<pair>
<repeat>10</repeat>
<delta_t>864000.0</delta_t>
</pair>
<pair>
<repeat>10</repeat>
<delta_t>8640000.0</delta_t>
</pair>
<pair>
<repeat>10</repeat>
<delta_t>86400000.0</delta_t>
</pair>
</timesteps>
</time_stepping>
</process>
<process ref="CT">
<type>DeltaX</type>
<time_stepping>
<timesteps>
<pair>
<repeat>10</repeat>
</pair>
<pair>
<repeat>10</repeat>
</pair>
<pair>
<repeat>10</repeat>
</pair>
<pair>
<repeat>10</repeat>
</pair>
<pair>
<repeat>10</repeat>
</pair>
<pair>
<repeat>10</repeat>
</pair>
<pair>
<repeat>10</repeat>
</pair>
<pair>
<repeat>10</repeat>
</pair>
</timesteps>
</time_stepping>
</process>
</processes>
<output>
<type>VTK</type>
<prefix>/tmp/tmpyo4hvupifeflow_test_simulation/2D_CT_model</prefix>
<timesteps>
<pair>
<repeat>1</repeat>
<each_steps>1</each_steps>
</pair>
</timesteps>
<variables>
<variable>single_species</variable>
<variable>HEAD_OGS</variable>
</variables>
<fixed_output_times>48384000</fixed_output_times>
</output>
<global_process_coupling>
<max_iter>1</max_iter>
<convergence_criteria>
<type>DeltaX</type>
<reltol>1e-10</reltol>
<type>DeltaX</type>
</convergence_criteria>
</global_process_coupling>
</time_loop>
<parameters>
<parameter>
<name>C0</name>
<value>0</value>
</parameter>
<parameter>
<name>p0</name>
<value>0</value>
</parameter>
<parameter>
<name>single_species_P_BC_MASS</name>
<type>MeshNode</type>
<mesh>single_species_P_BC_MASS</mesh>
<field_name>single_species_P_BC_MASS</field_name>
</parameter>
</parameters>
<process_variables>
<process_variable>
<components>1</components>
<order>1</order>
<initial_condition>C0</initial_condition>
<boundary_conditions>
<boundary_condition>
<type>Dirichlet</type>
<parameter>single_species_P_BC_MASS</parameter>
</boundary_condition>
</boundary_conditions>
</process_variable>
<process_variable>
<name>HEAD_OGS</name>
<order>1</order>
</process_variable>
<nonlinear_solvers>
<nonlinear_solver>
<name>basic_picard</name>
<type>Picard</type>
<max_iter>100</max_iter>
</nonlinear_solver>
</nonlinear_solvers>
<linear_solvers>
<linear_solver>
<lis>-i cg -p jacobi -tol 1e-10 -maxiter 100000</lis>
<eigen>
<solver_type>CG</solver_type>
<error_tolerance>1e-10</error_tolerance>
</eigen>
</linear_solver>
</linear_solvers>
</OpenGeoSysProject>
Run the model.
feflow_model.run()
OGS finished with project file /tmp/tmpyo4hvupifeflow_test_simulation/2D_CT_model.prj.
Execution took 2.6422176361083984 s
4. Read the last timestep and plot the results along a line on the upper edge of the mesh parallel to the x-axis.
label = ["OGS", "FEFLOW"][i]
ot.plot.line(
Concentration difference plotted on the mesh.
diff = ot.meshlib.difference(feflow_model.mesh, ogs_sim_res, concentration)
5.1 Concentration difference plotted along a line.
fig = ot.plot.line(
Total running time of the script: (0 minutes 3.823 seconds)
