Workflow: Hydraulic model - conversion, simulation and post-processing#
In this example we show how a simple flow/hydraulic FEFLOW model can be converted to a pyvista.UnstructuredGrid and then be simulated in ot.
Necessary imports
import tempfile
FeflowModel,
feflow_model = FeflowModel(feflow_model_box_Neumann, temp_dir / "boxNeumann")
feflow_model.mesh.plot(
show_edges=True,
off_screen=True,
scalars="P_HEAD",
cpos=[0, 1, 0.5],
print(feflow_model.mesh)
UnstructuredGrid (0x7b26fffe23e0)
N Cells: 11462
N Points: 6768
X Bounds: 0.000e+00, 1.000e+02
Y Bounds: 0.000e+00, 1.000e+02
Z Bounds: -1.000e+02, 0.000e+00
N Arrays: 23
Extract the subdomains conditions.
# Since there can be multiple boundary conditions in the subdomains,
# they are plotted iteratively.
if name != "topsurface":
plotter.subplot(i, 0)
Define endtime and time stepping in the project-file.
feflow_model.setup_prj(
end_time=int(1e8),
time_stepping=[(1, 10), (5, 100), (10, 1000), (10, 1e6), (1, 1e7)],
Run the model
feflow_model.run()
OGS finished with project file /tmp/tmppbvw3lwpfeflow_test_simulation/boxNeumann.prj.
Execution took 2.545957326889038 s
ms = ot.MeshSeries(temp_dir / "boxNeumann.pvd")
# Read the last timestep:
ogs_sim_res = pv.read(temp_dir / "boxNeumann_ts_1_t_1.000000.vtu")
ogs_sim_res.plot(
show_edges=True,
off_screen=True,
scalars="HEAD_OGS",
cpos=[0, 1, 0.5],
5.1 Plot the hydraulic head simulated in OGS with ogstools.plot.contourf.
head = ot.variables.Scalar(data_name="HEAD_OGS", data_unit="m", output_unit="m")
fig = ot.plot.contourf(ogs_sim_res.slice(normal="z", origin=[50, 50, 0]), head)
Calculate the difference to the FEFLOW simulation and plot it.
diff = feflow_model.mesh["P_HEAD"] - ogs_sim_res["HEAD_OGS"]
feflow_model.mesh["diff_HEAD"] = diff
show_edges=True,
off_screen=True,
scalars="diff_HEAD",
cpos=[0, 1, 0.5],
6.1 Plot the differences in the hydraulic head with ogstools.plot.contourf.
Slices are taken along the z-axis.
diff_head = ot.variables.Scalar(
slices = np.reshape(
list(feflow_model.mesh.slice_along_axis(n=4, axis="z")), (2, 2)
fig = ot.plot.contourf(slices, diff_head)
ax.set_title(f"z = {slice.center[2]:.1f} m", fontsize=32)
6.2 Slices are taken along the y-axis.
list(feflow_model.mesh.slice_along_axis(n=4, axis="y")), (2, 2)
ax.set_title(f"y = {slice.center[1]:.1f} m", fontsize=32)
Total running time of the script: (0 minutes 5.443 seconds)
