How to create Animations#
To demonstrate the creation of an animated plot we use a component transport example from the ogs benchmark gallery (https://www.opengeosys.org/docs/benchmarks/hydro-component/elder/).
You can choose which timesteps to render by passing either an int array corresponding to the indices, or a float array corresponding to the timevalues to render. If a requested timevalue is not part of the timeseries it will be interpolated. In this case every second frame will be interpolated.
timevalues = np.linspace(
mesh_series.timevalues[0], mesh_series.timevalues[-1], num=25
Now, let’s animate the saturation solution. A timescale at the top
indicates existing timesteps and the position of the current timevalue.
Note that rendering many frames in conjunction with large meshes might take
a really long time. We can pass a plot_func which can apply custom
formatting and / or plotting. To modify the domain, we can use the transform
method of MeshSeries.
def mesh_func(mesh: ot.Mesh) -> ot.Mesh:
"Clip the left half of the mesh."
return mesh.clip("-x", [0, 0, 0])
def plot_func(ax: plt.Axes, timevalue: float) -> None:
"Add the time to the title."
ax.set_title(f"{timevalue/(365.25*86400):.1f} yrs")
anim = mesh_series.transform(mesh_func).animate(
ot.variables.saturation, timevalues, plot_func, vmin=0, vmax=100, dpi=50
0%| | 0/25 [00:00<?, ?it/s]
4%|▍ | 1/25 [00:00<00:03, 6.15it/s]
8%|▊ | 2/25 [00:00<00:03, 6.14it/s]
12%|█▏ | 3/25 [00:00<00:03, 6.51it/s]
16%|█▌ | 4/25 [00:00<00:03, 6.35it/s]
20%|██ | 5/25 [00:00<00:03, 6.58it/s]
24%|██▍ | 6/25 [00:00<00:02, 6.42it/s]
28%|██▊ | 7/25 [00:01<00:02, 6.60it/s]
32%|███▏ | 8/25 [00:01<00:02, 6.45it/s]
36%|███▌ | 9/25 [00:01<00:02, 6.61it/s]
40%|████ | 10/25 [00:01<00:02, 6.47it/s]
44%|████▍ | 11/25 [00:01<00:02, 6.62it/s]
48%|████▊ | 12/25 [00:01<00:02, 6.47it/s]
52%|█████▏ | 13/25 [00:01<00:01, 6.62it/s]
56%|█████▌ | 14/25 [00:02<00:01, 6.47it/s]
60%|██████ | 15/25 [00:02<00:01, 6.62it/s]
64%|██████▍ | 16/25 [00:02<00:01, 6.46it/s]
68%|██████▊ | 17/25 [00:02<00:01, 6.60it/s]
72%|███████▏ | 18/25 [00:02<00:01, 6.45it/s]
76%|███████▌ | 19/25 [00:03<00:01, 5.20it/s]
80%|████████ | 20/25 [00:03<00:00, 5.44it/s]
84%|████████▍ | 21/25 [00:03<00:00, 5.81it/s]
88%|████████▊ | 22/25 [00:03<00:00, 5.91it/s]
92%|█████████▏| 23/25 [00:03<00:00, 6.19it/s]
96%|█████████▌| 24/25 [00:03<00:00, 6.17it/s]
96%|█████████▌| 24/25 [00:03<00:00, 6.04it/s]
The animation can be saved (as mp4) like so:
ot.plot.utils.save_animation(anim, "Saturation", fps=5)
Total running time of the script: (0 minutes 9.292 seconds)
