How to Create Time Slices#
In this example we show how to create a filled contourplot of transient data over a sampling line. For this purpose we use a component transport example from the ogs benchmark gallery (https://www.opengeosys.org/docs/benchmarks/hydro-component/elder/).
Let’s load the data which we want to investigate.
mesh_series = examples.load_meshseries_CT_2D_XDMF().scale(time=("s", "a"))
y = mesh_series[0].center[1] # flat y coordinate of this 2D mesh is not 0
si = ot.variables.saturation
Now we setup two sampling lines.
pts_vert = np.linspace([25, y, -75], [25, y, 75], num=100)
pts_diag = np.linspace([25, y, 75], [100, y, 0], num=100)
fig = mesh_series.mesh(-1).plot_contourf(si, vmin=0)
fig.axes[0].plot(pts_vert[:, 0], pts_vert[:, 2], "-k", linewidth=3)
fig.axes[0].plot(pts_diag[:, 0], pts_diag[:, 2], "-.k", linewidth=3)
[<matplotlib.lines.Line2D object at 0x7b2706103a30>]
Here, we first show a regular line sample plot for the vertical sampling line for each timestep.
fig, ax = plt.subplots(figsize=[15, 8])
for mesh, timevalue in zip(mesh_series, mesh_series.timevalues, strict=True):
sample = pv.PolyData(pts_vert).sample(mesh)
color = str(0.8 * timevalue / mesh_series.timevalues[-1])
label = f"{timevalue:.1f} a"
fig = ot.plot.line(
sample, si, "z", ax=ax, label=label, color=color, fontsize=20
As the above kind of plot is getting cluttered for lots of timesteps we
provide a function to create a filled contour plot over the transient data.
The function plot_time_slice()
automatically detects if the line lies on a cardinal direction and labels the
y-axes with the changing spatial dimension.
fig = mesh_series.plot_time_slice(si, pts_vert)
By default the plot is smoothened with interpolation. When deactivated, we see the edges of the raw sampled data. When using the interpolation, be sure to adjust the number of sampling points if the MeshSeries contains a lot of small timesteps.
fig = mesh_series.plot_time_slice(si, pts_vert, interpolate=False)
If the line doesn’t point in a cardinal direction the distance along the line is used for the y-axis by default. You can however, specify if you want to use spatial dimension via the argument “y_axis”. This may be useful when plotting data of an edge / boundary of the mesh.
fig = mesh_series.plot_time_slice(si, pts_diag)
Total running time of the script: (0 minutes 1.597 seconds)
