Read mesh from file (vtu or xdmf) into pyvista mesh#
To read your own data as a MeshSeries you can do:
MeshSeries takes as mandatory argument a str OR pathlib.Path that represents the location of the pvd or xdmf file. Here, we load example data and print the meta information:
ms
<ogstools.meshlib.mesh_series.MeshSeries object at 0x7b2716a0f220>
Accessing time values#
Time values (and spatial coordinates) can be unit transformed via
scale(). Either pass a tuple
to convert from the first to the second unit or pass a scaling factor.
print(f"First 3 time values are: {ms.timevalues[:3]} s.")
ms = ms.scale(time=("s", "h"))
print(f"Last time value is: {ms.timevalues[-1]} h.")
ms = ms.scale(time=3600.0)
print(f"Last time value is: {ms.timevalues[-1]} s.")
First 3 time values are: [ 0. 900. 1800.] s.
Last time value is: 24.0 h.
Last time value is: 86400.0 s.
Accessing meshes#
To get a single mesh at a specified timestep you can use the mesh() method of a MeshSeries object (in this example: ms). Another way to to do so is by indexing the MeshSeries object with brackets (ms[timestep]). Besides custom ogstools functions you can use all available pyvista functions. Here we use pyvista’s plot function.
mesh_ts10 = ms.mesh(10) # or ms[10]
Indexing#
MeshSeries.values(“<variable_name>”)` returns a numpy ndarray. It allows multidimensional indexing on ndarrays.
Typically, the first dimension is the time step, second dimension is the number of points/cells, and the last dimension is the number of components of the variable.
By default, values would read the entire dataset. If only a subset of the
MeshSeries should be read you can select the relevant timesteps by indexing /
slicing the MeshSeries directly. This selection will also be adhered to if you
read individual meshes.
# Temperature is a scalar, Darcy velocity is a vector with 2 components.
# Both are defined at points.
print("Entire dataset:", np.shape(ms.values("temperature")))
print("Every second timestep:", np.shape(ms[::2].values("temperature")))
print("Last two steps:", np.shape(ms[-2:].values("darcy_velocity")))
Entire dataset: (97, 190)
Every second timestep: (49, 190)
Last two steps: (2, 190, 2)
To select points or cells you can use the extract method to specify the
corresponding ids.
temp_at_points = ms.extract([2, 3, 4]).values("temperature")
print("Data on extracted points:", np.shape(temp_at_points))
print("Temperatures at last timestep:", temp_at_points[-1])
Data on extracted points: (97, 3)
Temperatures at last timestep: [352.9994477 303. 353.00000001]
You can also use pyvista dataset filters to transform the domain for the
entire MeshSeries.
ms_right_half = ms.transform(
lambda mesh: mesh.clip("x", mesh.center, crinkle=True)
temp_right_half = ms_right_half.values("temperature")
print("Data on clipped domain:", np.shape(temp_right_half))
Data on clipped domain: (97, 114)
Let’s plot the last timestep of the transformed MeshSeries.
fig = ms_right_half[-1].plot_contourf("temperature")
Total running time of the script: (0 minutes 1.065 seconds)
