Spatial refinement - steady state diffusion#
temp_dir = Path(mkdtemp(suffix="steady_state_diffusion"))
report_name = str(temp_dir / "report.ipynb")
result_paths = []
The meshes and their boundaries are generated easily via gmsh and
ogstools.meshlib.gmsh_converter.meshes_from_gmsh.
Then we run the different simulations with increasingly fine spatial
discretization via ogs6py and store the results for the convergence study.
refinements = 6
msh_path = temp_dir / "square.msh"
ot.meshlib.rect(
meshes = ot.meshes_from_gmsh(filename=msh_path, log=False)
pv.save_meshio(Path(temp_dir, name + ".vtu"), mesh)
output_file=temp_dir / "default.prj",
input_file=examples.prj_steady_state_diffusion,
ogs_args = f"-m {temp_dir} -o {temp_dir}"
result_paths += [str(temp_dir / (prefix + ".pvd"))]
OGS finished with project file /tmp/tmp5h2tjt4gsteady_state_diffusion/default.prj.
Execution took 0.09217000007629395 s
Execution took 0.10022521018981934 s
Execution took 0.09705114364624023 s
Execution took 0.09416055679321289 s
Execution took 0.09518790245056152 s
Execution took 0.10249161720275879 s
analytical_solution_path = temp_dir / "analytical_solution.vtu"
solution = examples.analytical_diffusion(
ot.MeshSeries(result_paths[-1]).mesh(0)
output_name=report_name,
mesh_paths=result_paths,
timevalue=1,
refinement_ratio=2.0,
Darcy velocity convergence#
variable_name="velocity",
timevalue=1,
Total running time of the script: (0 minutes 15.753 seconds)
