Variable presets and data transformation#
ogstools.variables provides classes (Scalar, Vector, Matrix) which
encapsulate unit handling and data transformation for simplified processing of
mesh data. There are also several predefined variables.
ot.variables.get_dataframe()
Scalar, Vector and Matrix inherit from the class Variable with its
transform() function.
This function converts the argument from data_unit to output_unit and
applies a function if specified. In this case we convert from K to °C:
ot.variables.temperature.transform(273.15, strip_unit=False)
You can also create your own variables by creating a Scalar, Vector or Matrix variable. The following doesn’t do any unit conversion.
custom_temperature = ot.variables.Scalar(
data_name="temperature", data_unit="K", output_unit="K"
custom_temperature.transform(273.15, strip_unit=False)
Or use existing presets as a template and replace some parameters:
custom_temperature = ot.variables.temperature.replace(output_unit="°F")
Components of Vector variables and Matrix variables can be accessed with
bracket indexing. Vector variables
should be of length 2 or 3 corresponding to the dimension.
Matrix variables likewise should be of
length 4 [xx, yy, zz, xy] or 6 [xx, yy, zz, xy, yz, xz].
ot.variables.displacement[1].transform([0.01, 0.02, 0.03], strip_unit=False)
ot.variables.strain["xx"].transform(
[0.01, 0.02, 0.03, 0.04, 0.05, 0.06], strip_unit=False
Magnitude of a 2D displacement vector:
ot.variables.displacement.magnitude.transform([0.03, 0.04], strip_unit=False)
We suggest specifying the variables and their transformations once.
These can be reused in different kind of post processing. When plotting
with ogstools.plot we can use these presets to simplify the
task of processing the data (e.g. calculate the von Mises stress):
fig = ot.plot.contourf(
examples.load_mesh_mechanics_2D(), ot.variables.stress.von_Mises
Have a look at Plotting the data for more examples.
Total running time of the script: (0 minutes 0.234 seconds)
