This example demonstrates how to use ogstools.meshlib.gmsh_BHE.gen_bhe_mesh to create
a Borehole Heat Exchanger (BHE) mesh.
from pyvista.plotting import Plotter
from ogstools.meshlib.gmsh_BHE import BHE, Groundwater, gen_bhe_mesh
Introduction#
This example shows the general usage of ogstools.meshlib.gmsh_BHE.gen_bhe_mesh and how some of
the parameters will effect the mesh. This section demonstrates the mesh
generation with only three soil layers, groundwater flow in one layer
and three BHE’s. However, this tool provides multiple soil layers,
groundwater flow in multiple layers and multiple BHE’s. The mesh sizes
provides good initial values for the most Heat-Transport-BHE simulations
in OGS. They can also be set by the user, to customize the mesh.
Feel free to try it out!
Create a simple prism mesh#
Generate a customizable prism BHE mesh:
tmp_dir = Path(mkdtemp())
vtu_file = tmp_dir / "bhe_prism.vtu"
bhe_meshes = gen_bhe_mesh(
length=150,
width=100,
layer=[50, 50, 50],
groundwater=Groundwater(
begin=-30, isolation_layer_id=1, flow_direction="+x"
BHE_Array=[
meshing_type="prism",
out_name=vtu_file,
Load the domain mesh and all submeshes as well as extract the BHE lines:
mesh = pv.read(tmp_dir / bhe_meshes[0])
top_mesh = pv.read(tmp_dir / bhe_meshes[1])
bottom_mesh = pv.read(tmp_dir / bhe_meshes[2])
gw_mesh = pv.read(tmp_dir / bhe_meshes[3])
bhe_line = mesh.extract_cells_by_type(pv.CellType.LINE)
Visualize the mesh:
top_mesh = top_mesh.translate((0, 0, 10), inplace=False)
bottom_mesh = bottom_mesh.translate((0, 0, -10), inplace=False)
gw_mesh = gw_mesh.translate((-10, 0, 0), inplace=False)
p = Plotter()
p.add_mesh(mesh, style="wireframe", color="grey")
p.add_mesh(
mesh.clip("x", bhe_line.center, crinkle=True),
show_edges=True,
scalars="MaterialIDs",
cmap="Accent",
categories=True,
scalar_bar_args={"vertical": True, "n_labels": 2, "fmt": "%.0f"},
p.add_mesh(bhe_line, color="r", line_width=3)
p.add_mesh(top_mesh, show_edges=True)
p.add_mesh(bottom_mesh, show_edges=True)
p.add_mesh(gw_mesh, show_edges=True)
p.add_axes()
p.show()
Create a simple structured mesh#
Generate a customizable structured BHE mesh:
vtu_file = tmp_dir / "bhe_structured.vtu"
length=150,
width=100,
layer=[50, 50, 50],
BHE_Array=[
meshing_type="structured",
out_name=vtu_file,
Visualize the mesh:
p = Plotter()
p.add_mesh(
show_edges=True,
cmap="Accent",
categories=True,
p.add_axes()
p.show()
Create an advanced structured mesh#
Generate a customizable structured BHE mesh with advanced mesh sizing options (using gmsh). To understand the specific behaviour of every mesh parameter, test each one after another.
vtu_file = tmp_dir / "bhe_structured_advanced.vtu"
length=150,
width=100,
layer=[50, 50, 50],
groundwater=Groundwater(-30, 1, "+x"),
BHE_Array=[
BHE(50, 40, -1, -60, 0.076),
BHE(50, 50, -1, -60, 0.076),
BHE(50, 60, -1, -60, 0.076),
target_z_size_coarse=10, # default value 7.5
target_z_size_fine=2, # default value 1.5
n_refinement_layers=1, # default value 2
dist_box_x=15, # default value 10
propagation=1.2, # default value 1.1
inner_mesh_size=8, # default value 5
outer_mesh_size=12, # default value 10
out_name=vtu_file,
Visualize the mesh:
p = Plotter()
p.add_mesh(
show_edges=True,
cmap="Accent",
categories=True,
p.add_axes()
p.show()
Total running time of the script: (0 minutes 16.399 seconds)
