Feflowlib: How to get started with the FEFLOW converter.#
This example shows how a FEFLOW model can be converted and simulated in OGS.
Necessary imports.
from ogstools import FeflowModel
feflow_model_2D_CT_t_560,
feflow_model_2D_HT,
feflow_model_box_Robin,
Convert the models.
feflow_model_H = FeflowModel(
feflow_model_box_Robin, temp_dir / "3D_H_model.vtu"
feflow_model_HC = FeflowModel(
feflow_model_2D_CT_t_560, temp_dir / "2D_HC_model.vtu"
feflow_model_HT = FeflowModel(feflow_model_2D_HT, temp_dir / "2D_HT_model.vtu")
2. Define simulation times. Simulate the steady state diffusion process in OGS for the H-model.
feflow_model_H.setup_prj(steady=True)
feflow_model_HC.setup_prj(
end_time=int(4.8384e07),
time_stepping=list(
feflow_model_HT.setup_prj(end_time=1e11, time_stepping=[(1, 1e10)])
Run the simulations.
feflow_model_H.run()
feflow_model_HC.run()
feflow_model_HT.run()
ogs -o . /tmp/ogstools_root/examples/feflow_test_simulatione561c7aa165440959f241e57d03f3979/3D_H_model.prj
['ogs', '-o', '.', '/tmp/ogstools_root/examples/feflow_test_simulatione561c7aa165440959f241e57d03f3979/3D_H_model.prj']
ogs -o . /tmp/ogstools_root/examples/feflow_test_simulatione561c7aa165440959f241e57d03f3979/2D_HC_model.prj
['ogs', '-o', '.', '/tmp/ogstools_root/examples/feflow_test_simulatione561c7aa165440959f241e57d03f3979/2D_HC_model.prj']
ogs -o . /tmp/ogstools_root/examples/feflow_test_simulatione561c7aa165440959f241e57d03f3979/2D_HT_model.prj
['ogs', '-o', '.', '/tmp/ogstools_root/examples/feflow_test_simulatione561c7aa165440959f241e57d03f3979/2D_HT_model.prj']
Total running time of the script: (0 minutes 4.972 seconds)
