Workflow with Feflowlib: Hydraulic model - conversion, simulation and post-processing#
In this example we show how a simple flow/hydraulic FEFLOW model can be converted to a pyvista.UnstructuredGrid and then be simulated in ot.
  1. Necessary imports
from ogstools.feflowlib import FeflowModel
feflow_model = FeflowModel(feflow_model_box_Neumann, temp_dir / "boxNeumann")
feflow_model.mesh.plot(
    show_edges=True,
    off_screen=True,
    scalars="P_HEAD",
    cpos=[0, 1, 0.5],
print(feflow_model.mesh)
plot E feflowlib H simulation
UnstructuredGrid (0x7f57dda59720)
  N Cells:    11462
  N Points:   6768
  X Bounds:   0.000e+00, 1.000e+02
  Y Bounds:   0.000e+00, 1.000e+02
  Z Bounds:   -1.000e+02, 0.000e+00
  N Arrays:   23
  1. Extract the subdomains conditions.
# Since there can be multiple boundary conditions in the subdomains,
# they are plotted iteratively.
    if name != "topsurface":
        plotter.subplot(i, 0)
  1. Define endtime and time stepping in the project-file.
feflow_model.setup_prj(
    end_time=int(1e8),
    time_stepping=[(1, 10), (5, 100), (10, 1000), (10, 1e6), (1, 1e7)],
  1. Run the model
feflow_model.run()
 ogs  -o . /tmp/ogstools_root/examples/feflow_test_simulation4ff923b9f298402fba4a529cca2270c8/boxNeumann.prj
['ogs', '-o', '.', '/tmp/ogstools_root/examples/feflow_test_simulation4ff923b9f298402fba4a529cca2270c8/boxNeumann.prj']
  1. Read the results and plot them.
ms = ot.MeshSeries(temp_dir / "boxNeumann.pvd")
# Read the last timestep:
ogs_sim_res = ot.mesh.read(temp_dir / "boxNeumann_ts_1_t_1.000000.vtu")
ogs_sim_res.plot(
    show_edges=True,
    off_screen=True,
    scalars="HEAD_OGS",
    cpos=[0, 1, 0.5],
5.1 Plot the hydraulic head simulated in OGS with ogstools.plot.contourf.
head = ot.variables.Scalar(data_name="HEAD_OGS", data_unit="m", output_unit="m")
fig = ot.plot.contourf(ogs_sim_res.slice(normal="z", origin=[50, 50, 0]), head)
  1. Calculate the difference to the FEFLOW simulation and plot it.
diff = feflow_model.mesh["P_HEAD"] - ogs_sim_res["HEAD_OGS"]
feflow_model.mesh["diff_HEAD"] = diff
    show_edges=True,
    off_screen=True,
    scalars="diff_HEAD",
    cpos=[0, 1, 0.5],
6.1 Plot the differences in the hydraulic head with ogstools.plot.contourf. Slices are taken along the z-axis.
diff_head = ot.variables.Scalar(
slices = np.reshape(
    list(feflow_model.mesh.slice_along_axis(n=4, axis="z")), (2, 2)
fig = ot.plot.contourf(slices, diff_head)
    ax.set_title(f"z = {slice.center[2]:.1f} m", fontsize=32)
z = -99.0 m, z = -66.3 m, z = -33.7 m, z = -1.0 m
6.2 Slices are taken along the y-axis.
    list(feflow_model.mesh.slice_along_axis(n=4, axis="y")), (2, 2)
    ax.set_title(f"y = {slice.center[1]:.1f} m", fontsize=32)
y = 1.0 m, y = 33.7 m, y = 66.3 m, y = 99.0 m
Total running time of the script: (0 minutes 5.945 seconds)
