Feflowlib: How to modify the project-file after converting a FEFLOW model.#
This example shows how to convert a FEFLOW model and how to modify the corresponding OGS project file and boundary meshes after conversion.
  1. Necessary imports
temp_dir = ot.definitions.temp_dir("converted_models", "examples")
feflow_model = ot.FeflowModel(feflow_model_2D_CT_t_560, temp_dir / "CT_model")
  1. Get the mesh and run the FEFLOW model in OGS.
mesh = feflow_model.mesh
feflow_model.setup_prj(
    end_time=1e11, time_stepping=[(1, 1e6), (1, 1e8), (1, 1e10)]
feflow_model.run()
 ogs  -o . /tmp/ogstools_root/examples/converted_models35b5d0850e5045b4bcb081afea466b46/CT_model.prj
['ogs', '-o', '.', '/tmp/ogstools_root/examples/converted_models35b5d0850e5045b4bcb081afea466b46/CT_model.prj']
  1. Plot the results.
ms = ot.MeshSeries(temp_dir / "CT_model.pvd")
ot.plot.contourf(ogs_sim_res, "single_species")
plot C feflowlib prj
4. Replace the scalar pore diffusion constant by a tensor to introducec anisotropy. How to manipulate a prj file also is explained in this example: # Run a simulation.
tensor = """
        1e-9 1e-12
feflow_model.project.replace_phase_property_value(
    mediumid=0, component="single_species", name="pore_diffusion", value=tensor
feflow_model.save()
model_prjfile = ET.parse(temp_dir / "CT_model.prj")
ET.dump(model_prjfile)
<OpenGeoSysProject>
    <meshes>
        <mesh>CT_model.vtu</mesh>
        <mesh>single_species_P_BC_MASS.vtu</mesh>
    </meshes>
    <processes>
        <process>
            <name>CT</name>
            <secondary_variables>
            </secondary_variables>
            <process_variables>
                <pressure>HEAD_OGS</pressure>
                <concentration>single_species</concentration>
            </process_variables>
        </process>
    </processes>
    <media>
        <medium id="0">
            <phases>
                <phase>
                    <type>AqueousLiquid</type>
                    <properties>
                        <property>
                            <name>viscosity</name>
                            <type>Constant</type>
                            <value>1</value>
                        </property>
                        <property>
                            <name>density</name>
                            <value>1</value>
                        </property>
                    </properties>
                    <components>
                        <component>
                            <name>single_species</name>
                            <properties>
                                <property>
                                    <name>decay_rate</name>
                                    <value>0.0</value>
                                </property>
                                <property>
                                    <name>pore_diffusion</name>
                                    <value>
        1e-9 1e-12
        </value>
                                </property>
                                <property>
                                    <value>16441.72737282367</value>
                                </property>
                            </properties>
                        </component>
                    </components>
                </phase>
            </phases>
            <properties>
                <property>
                    <name>porosity</name>
                    <value>0.10999999940395355</value>
                </property>
                <property>
                    <name>longitudinal_dispersivity</name>
                    <value>0.0</value>
                </property>
                <property>
                    <name>transversal_dispersivity</name>
                    <value>0.0</value>
                </property>
                <property>
                    <name>permeability</name>
                </property>
            </properties>
        </medium>
    </media>
    <time_loop>
        <processes>
            <process ref="CT">
                <convergence_criterion>
                    <type>DeltaX</type>
                    <norm_type>NORM2</norm_type>
                    <reltol>1e-6</reltol>
                </convergence_criterion>
                <time_discretization>
                    <type>BackwardEuler</type>
                </time_discretization>
                <time_stepping>
                    <t_initial>0</t_initial>
                    <t_end>100000000000.0</t_end>
                    <timesteps>
                        <pair>
                            <repeat>1</repeat>
                            <delta_t>1000000.0</delta_t>
                        </pair>
                        <pair>
                            <repeat>1</repeat>
                            <delta_t>100000000.0</delta_t>
                        </pair>
                        <pair>
                            <repeat>1</repeat>
                            <delta_t>10000000000.0</delta_t>
                        </pair>
                    </timesteps>
                </time_stepping>
            </process>
            <process ref="CT">
                    <type>DeltaX</type>
                <time_stepping>
                    <timesteps>
                        <pair>
                            <repeat>1</repeat>
                        </pair>
                        <pair>
                            <repeat>1</repeat>
                        </pair>
                        <pair>
                            <repeat>1</repeat>
                        </pair>
                    </timesteps>
                </time_stepping>
            </process>
        </processes>
        <output>
            <type>VTK</type>
            <prefix>/tmp/ogstools_root/examples/converted_models35b5d0850e5045b4bcb081afea466b46/CT_model</prefix>
            <timesteps>
                <pair>
                    <repeat>1</repeat>
                    <each_steps>1</each_steps>
                </pair>
            </timesteps>
            <variables>
                <variable>single_species</variable>
                <variable>HEAD_OGS</variable>
            </variables>
            <fixed_output_times>100000000000.0</fixed_output_times>
        </output>
        <global_process_coupling>
            <max_iter>1</max_iter>
            <convergence_criteria>
                    <type>DeltaX</type>
                    <reltol>1e-10</reltol>
                    <type>DeltaX</type>
            </convergence_criteria>
        </global_process_coupling>
    </time_loop>
    <parameters>
        <parameter>
            <name>C0</name>
            <value>0</value>
        </parameter>
        <parameter>
            <name>p0</name>
            <value>0</value>
        </parameter>
        <parameter>
            <name>single_species_P_BC_MASS</name>
            <type>MeshNode</type>
            <mesh>single_species_P_BC_MASS</mesh>
            <field_name>single_species_P_BC_MASS</field_name>
        </parameter>
    </parameters>
    <process_variables>
        <process_variable>
            <components>1</components>
            <order>1</order>
            <initial_condition>C0</initial_condition>
            <boundary_conditions>
                <boundary_condition>
                    <type>Dirichlet</type>
                    <parameter>single_species_P_BC_MASS</parameter>
                </boundary_condition>
            </boundary_conditions>
        </process_variable>
        <process_variable>
            <name>HEAD_OGS</name>
            <order>1</order>
        </process_variable>
    <nonlinear_solvers>
        <nonlinear_solver>
            <name>basic_picard</name>
            <type>Picard</type>
            <max_iter>100</max_iter>
        </nonlinear_solver>
    </nonlinear_solvers>
    <linear_solvers>
        <linear_solver>
            <lis>-i cg -p jacobi -tol 1e-10 -maxiter 100000</lis>
            <eigen>
                <solver_type>CG</solver_type>
                <error_tolerance>1e-10</error_tolerance>
            </eigen>
        </linear_solver>
    </linear_solvers>
</OpenGeoSysProject>
  1. Remove some points of the boundary mesh, which is part of the subdomains.
bounds = [0.037, 0.039, 0.003, 0.006, 0, 0]
new_bc_mesh = feflow_model.subdomains["single_species_P_BC_MASS"].clip_box(
    bounds, invert=False
feflow_model.subdomains["single_species_P_BC_MASS"] = new_bc_mesh
  1. Run the model.
Total running time of the script: (0 minutes 1.982 seconds)
