Run a simulation - Step by step#
With interactive execution, OpenGeoSys provides a Python interface that lets you advance a simulation one step at a time, inspect intermediate results, and react before continuing. This mechanism underlies what we mean by Co-simulation: the simulation can exchange information with external analyses or tools during runtime—for example, by dynamically adjusting boundary conditions. In this guide, we will show how to:
Imports and definitions#
from ogs import OGSMesh
Select a Project#
We will start with a simple liquid flow example and set the OGS execution to interactive.
model.execution.interactive = True
Initialize the simulation and first step#
Use the same arguments as when calling OGS from command line, a list of possible argument are documented under https://www.opengeosys.org/docs/userguide/basics/cli-arguments/
By constructing a SimulationController object we start OpenGeoSys and it (only!) runs time step 0.
simc_1 = model.controller()
print(f"The current simulation time is: {simc_1.current_time} s.")
print(f"The end time defined is: {simc_1.end_time} s.")
The current simulation time is: 0.0 s.
The end time defined is: 100.0 s.
Advance the simulation by a one step#
status = simc_1.execute_time_step()
The current simulation time is: 10.0 s.
Basic simulation loop#
The simulation runs step-by-step until a user specified condition is met. This further allows you to manipulate data arrays associated with the mesh or adapt the logic inside the loop.
while (
    # Here, the condition is when simulation reaches the end time:
    simc_1.current_time
    < simc_1.end_time
    # Add here your specific code with mesh manipulation:
    my_mesh: OGSMesh = simc_1.mesh("domain")
sim = simc_1.run()
print(sim)
Simulation id: 20260601_131502_247585
   (not saved (planned: file:///tmp/ogstools_root/Simulation/20260601_131502_247585))
  Model: saved to file:///tmp/ogstools_root/Model/20260601_131501_817270
  Result: saved to file:///tmp/ogstools_root/Result/20260601_131501_933930
  Log file: file:///tmp/ogstools_root/Result/20260601_131501_933930/log.txt
  MeshSeries: file:///tmp/ogstools_root/Result/20260601_131501_933930/LiquidFlow_Simple.pvd
  Status: completed successfully (results available)
Advance examples with mesh manipulation#
Manipulate the mesh with either
Total running time of the script: (0 minutes 0.493 seconds)
