Feflowlib: How to work with FEFLOW data in pyvista.#
In this example we show how a simple FEFLOW model consisting of two layers can be converted to a pyvista.UnstructuredGrid.
Let us convert only the points and cells at first.
import ifm_contrib as ifm
import ogstools as ogs
from ogstools.examples import feflow_model_2layers
convert_geometry_mesh,
update_geometry,
# Load a FEFLOW model (.fem) or FEFLOW results file (.dac) as a FEFLOW document.
feflow_model = ifm.loadDocument(str(feflow_model_2layers))
pv_mesh = convert_geometry_mesh(feflow_model)
pv_mesh.plot(show_edges=True, off_screen=True)
To this mesh we add point and cell data.
pv_mesh = update_geometry(pv_mesh, feflow_model)
pv_mesh.plot(scalars="P_HEAD", show_edges=True, off_screen=True)
print(pv_mesh)
UnstructuredGrid (0x7cd485b01300)
N Cells: 32
N Points: 75
X Bounds: 3.000e+01, 7.000e+01
Y Bounds: 3.000e+01, 7.000e+01
Z Bounds: -2.000e+01, 0.000e+00
N Arrays: 22
This allows to use the FEFLOW model for OGS
simulation or to observe it in Paraview`
pv_mesh.save("2layers_model.vtu")
Use the ogstools plotting functionalities.
fig = ogs.plot.contourf(pv_mesh.slice("z"), "P_HEAD")
Total running time of the script: (0 minutes 0.675 seconds)
