Spatial refinement - steady state diffusion#
Nasa convergence reference
More comprehensive reference
tmp_path = Path(mkdtemp(prefix="steady_state_diffusion"))
report_name = str(tmp_path / "report.ipynb")
The meshes and their boundaries are generated easily via gmsh and Meshes. from_gmsh(). Then we run the different simulations with increasingly fine spatial discretization via ogs6py and store the results for the convergence study.
refinements = 6
simulations_control = []
    meshes = ot.Meshes.from_gmsh(
        ot.gmsh_tools.rect(n_edge_cells=n_edge_cells, structured_grid=True),
        log=False,
    prj = ot.Project(input_file=examples.prj_steady_state_diffusion).copy(
        tmp_path / f"cells_{n_edge_cells}"
    prj.replace_text(prefix, ".//prefix")
    model = ot.Model(prj, meshes)
    sim_c = model.controller()
    simulations_control.append(sim_c)
simulations = [sim.run() for sim in simulations_control]
analytical_solution_path = tmp_path / "analytical_solution.vtu"
sim_last: ot.Simulation = simulations[-1]
solution = examples.anasol.diffusion_head_analytical(
    simulations[-1].meshseries[0]
analytical_solution_path = ot.mesh.save(solution)
plot convergence study steady state diffusion
result_paths = [sim.meshseries_file for sim in simulations]
    output_name=report_name,
    mesh_paths=result_paths,
    timevalue=1,
    refinement_ratio=2.0,
report
Darcy velocity convergence#
    variable_name="velocity",
    timevalue=1,
report
Total running time of the script: (0 minutes 25.151 seconds)
