How to Create Simple Mechanics Problem#
The following example consists of a simple mechanics problem. The source file can be found in the [OGS benchmark folder](https://gitlab.opengeosys.org/ogs/ogs/-/blob/master/Tests/Data/Mechanics/Linear/square_1e2.prj?ref_type=heads). The names of the method calls are based on the corresponding XML tags.
Initialize the ogs6py object:
output_dir = Path(mkdtemp())
Define geometry and/or meshes:
prj.geometry.add_geometry(filename="square_1x1.gml")
Set process and provide process related data:
prj.processes.set_process(
    name="SD",
    type="SMALL_DEFORMATION",
    integration_order="2",
    specific_body_force="0 0",
Define time stepping and output cycles:
prj.time_loop.add_process(
    process="SD",
    convergence_type="DeltaX",
    norm_type="NORM2",
    abstol="1e-15",
prj.time_loop.set_stepping(
    process="SD",
    type="FixedTimeStepping",
    t_initial="0",
    t_end="1",
    repeat="4",
    delta_t="0.25",
prj.time_loop.add_output(
    type="VTK",
    prefix="blubb",
    repeat="1",
    each_steps="10",
prj.media.add_property(
    medium_id="0",
    phase_type="Solid",
    name="density",
    type="Constant",
    value="1",
Define parameters needed for material properties and BC:
Set initial and boundary conditions:
prj.process_variables.set_ic(
    components="2",
    order="1",
prj.process_variables.add_bc(
    geometry="left",
    type="Dirichlet",
    component="0",
    parameter="dirichlet0",
    geometry="bottom",
    type="Dirichlet",
    component="1",
    geometry="top",
    type="Dirichlet",
    component="1",
    parameter="dirichlet1",
Set linear and nonlinear solver(s):
    type="Newton",
    max_iter="4",
    name="general_linear_solver",
    kind="lis",
    solver_type="cg",
    precon_type="jacobi",
    max_iteration_step="10000",
    error_tolerance="1e-16",
    kind="eigen",
    solver_type="CG",
    precon_type="DIAGONAL",
    kind="petsc",
    prefix="sd",
    solver_type="cg",
    precon_type="bjacobi",
Write project file to disc:
prj.write_input()
Execute file and pipe output to logfile out.log:
prj.run_model(
    logfile="out.log",
    args="-m " + str(EXAMPLES_DIR / "prj") + " -o " + str(output_dir),
Simulation: /tmp/tmpl3o7nio0/mechanics_new.prj
Execution took 0.13999700546264648 s
If the desired OGS version is not in PATH, a separate path containing the OGS binary can be specified. model.run_model(path=”~/github/ogs/build_mkl/bin”)
Total running time of the script: (0 minutes 0.147 seconds)
