Feflowlib: How to modify boundary conditions after conversion of a FEFLOW model.#
This example shows how boundary conditions can be modified after converting a FEFLOW model. First we will change the values of the boundary conditions and later we will show how to define a new boundary mesh.
Necessary imports
import tempfile
from ogstools.feflowlib import assign_bulk_ids
temp_dir = Path(tempfile.mkdtemp("converted_models"))
feflow_model = ot.FeflowModel(feflow_model_2D_HT, temp_dir / "HT_model")
mesh = feflow_model.mesh
print(mesh)
UnstructuredGrid (0x7f3d533e6320)
N Cells: 6260
N Points: 3228
X Bounds: -2.500e+02, 9.000e+02
Y Bounds: 3.500e+02, 6.500e+02
N Arrays: 33
Plot the temperature simulated in FEFLOW on the mesh.
This allows to use the FEFLOW model for OGS simulation or to observe it in Paraview`.
PosixPath('/tmp/tmpmbobgvlfconverted_models/HT_mesh.vtu')
Run the FEFLOW model in OGS.
feflow_model.run()
ms = ot.MeshSeries(temp_dir / "HT_model.pvd")
Plot the temperature simulated in OGS.
6. The boundary meshes are manipulated to alter the model. The original boundary conditions are shown in this example: Workflow with Feflowlib: Hydro-thermal model - conversion, simulation and post-processing 6.1 The Dirichlet boundary conditions for the hydraulic head are set to 0. Therefore, no water flows from the left to the right edge.
bc_flow = feflow_model.subdomains["P_BC_FLOW"]["P_BC_FLOW"]
feflow_model.subdomains["P_BC_FLOW"]["P_BC_FLOW"][bc_flow == 10] = 0
6.2 Overwrite the new boundary conditions and run the model.
6.3 The corresponding simulation results look like.
# Read the last timestep:
6.4 Create a new boundary mesh and overwrite the existing subdomains with this boundary mesh.
assign_bulk_ids(mesh)
# Get the points of the bulk mesh to build a new boundary mesh.
wanted_pts = [1492, 1482, 1481, 1491, 1479, 1480, 1839, 1840]
new_bc = mesh.extract_points(
[pt in wanted_pts for pt in mesh["bulk_node_ids"]],
adjacent_cells=False,
include_cells=False,
new_bc["bulk_node_ids"] = np.array(wanted_pts, dtype=np.uint64)
# Define the temperature values of these points.
new_bc["P_BC_HEAT"] = np.array([300] * len(wanted_pts), dtype=np.float64)
feflow_model.subdomains["P_BC_HEAT"] = new_bc
Run the new model and plot the simulation results.
Total running time of the script: (0 minutes 6.485 seconds)
