Visualizing 3D model data#
For visualizing 3D data it might make sense to plot multiple views / slices. To create them we use pyvista as it provides all the necessary functionality. If we want to plot multiple meshes, they have to be in a 2D numpy array. The shape of this array determines the number of rows and columns in our plot. First, let’s load 3D example data from pyvista and plot the only available data: “facies” with a native pyvista plot.
from pyvista import examples
mesh = examples.load_channels()
data = ot.variables.Scalar("facies", categoric=True, cmap="tab20")
section = mesh.clip("y", (0, 20, 0))
/builds/ogs/tools/ogstools/docs/examples/howto_plot/plot_contourf_3d.py:21: PyVistaDeprecationWarning:
plot_contourf_3d.py:21: Argument 'origin' must be passed as a keyword argument to function 'DataObjectFilters.clip'.
ot.plot.contourf(
    section, data, show_edges=False, opacities={0: 0.2}, interactive=False
# only plotting a part of the example, as using opacities is expensive
# performance-wise and the example is big.
plot contourf 3d
It might make sense to plot multiple views / slices of 3D data. To create them we use the slicing functions of pyvista. If we want to plot multiple meshes, they have to be in a 2D numpy array. The shape of this array determines the number of rows and columns in our plot.
Let’s create multiple slices along the z axis and plot them in a 2 by 2 grid.
slices = np.reshape(list(mesh.slice_along_axis(n=4, axis="z")), (2, 2))
fig = ot.plot.contourf(slices, data, figsize=[8, 6], fontsize=12)
    ax.set_title(f"z = {slice.center[2]:.1f}")
z = 1.0, z = 33.7, z = 66.3, z = 99.0
We can also slice along the y-axis and plot the meshes in one row.
slices = np.reshape(mesh.slice_along_axis(n=3, axis="y"), (1, -1))
    ax.set_title(f"y = {slice.center[1]:.1f}")
y = 2.5, y = 125.0, y = 247.5
Arbitrary oriented slices are also possible. They get projected to the cardinal plane, from which they have the least rotational offset.
fig = ot.plot.contourf(mesh.slice([1, -2, 0]), data)
plot contourf 3d
Total running time of the script: (0 minutes 9.762 seconds)
