Logparser: Introduction#
Complete example#
from ogstools.examples import log_const_viscosity_thermal_convection
df_ts_it
The log file#
Running ogs in the command line outputs the logs into the console output. With
tee in Linux and Mac
and
Tee-Object
in Windows Powershell the log gets directed into a file and into the console.
Linux/Mac:
ogs <your_prj_file> | tee <your_log_file>Windows:
ogs <your_prj_file> | Tee-Object -FilePath <your_log_file>
For first step we recommend to use either `ogs -l info` or ogs - l debug.
Make sure the log file does not contain
ANSI escape (e.g.color) code.
You can remove it with: cat ogs.log | sed 's/\x1b\[[0-9;]*m//g' > ogs.log
Parsing steps#
The functions ogstools.logparser.parse_file and
ogstools.logparser.fill_ogs_context are explained in
Logparser: Advanced topics.
All predefined analyses need the result of fill_ogs_context.
Here const_viscosity_thermal_convection_log is string representing the
location of the ogs log file.
/builds/ogs/tools/ogstools/ogstools/examples/logs/ConstViscosityThermalConvection.log
Use predefined analyses#
ogstools.logparser.time_step_vs_iterations is one of many predefined
analyses. All possibilities are shown here:
Logparser: Predefined Analyses.
Here we are interested in every time step of the simulation and how many
iterations have been needed.
The predefined analyses only work with logs from ogs run with level info or finer (debug), like ogs -l info or ogs - l debug.
(see
OGS Developer Guide - log and debug output
df_ts_it
Pandas to plot#
You can directly use
plot
<https://pandas.pydata.org/pandas-docs/stable/reference/api/pandas.DataFrame.plot.html>`_ from pandas.
ax = df_ts_it.plot(
y="iteration_number", xlabel="time_step", grid=True, legend=False
df_ts_it.plot(
y="step_start_time",
xlabel="time_step",
ax=ax,
secondary_y=True,
grid=True,
legend=False,
ax.set_ylabel("iteration number")
ax.yaxis.label.set_color("C0") # colour matches the left line
ax.tick_params(axis="y", colors="C0")
ax_right = ax.right_ax
ax_right.set_ylabel("simulation time")
ax_right.yaxis.label.set_color("C1")
ax_right.tick_params(axis="y", colors="C1")
lines, labels = ax.get_legend_handles_labels()
lines2, labels2 = ax_right.get_legend_handles_labels()
ax.legend(lines + lines2, labels + labels2, loc="upper left")
<matplotlib.legend.Legend object at 0x7f3d67282cc0>
Total running time of the script: (0 minutes 0.111 seconds)
