Spatial & temporal refinement - nuclear decay#
This example shows one possible implementation of how to do a convergence study with spatial and temporal refinement. For this, a simple model using a time dependent heat source on one side and constant temperature on the opposite side was set up. The heat source is generated with the ogstools.physics.nuclearwasteheat model.
Nasa convergence reference
More comprehensive reference
from ogstools import examples, physics, studies, workflow
temp_path = Path(mkdtemp(prefix="nuclear_decay"))
Let’s run the different simulations with increasingly fine spatial and temporal discretization via ogs6py. The mesh and its boundaries are generated easily via gmsh and Meshes. from_gmsh(). First some definitions:
n_refinements = 4
prefix = "stepsize_{0}"
sim_results = []
msh_path = temp_path / "rect.msh"
script_path = Path(examples.pybc_nuclear_decay).parent
Now the actual simulations:
for dt, n_cells in zip(time_step_sizes, edge_cells, strict=False):
    ot.gmsh_tools.rect(
        lengths=100.0, n_edge_cells=(n_cells, 1), out_name=msh_path
    meshes = ot.Meshes.from_gmsh(msh_path, log=False)
    mesh_path = temp_path / f"dt_{dt}_n_cells_{n_cells}"
    mesh_path.mkdir(parents=True, exist_ok=True)
    meshes.save(mesh_path)
    prj = ot.Project(output_file=temp_path / "default.prj", input_file=prj_path)
    prj.replace_text(str(dt * sec_per_yr), ".//delta_t")
    prj.replace_text(prefix.format(dt), ".//prefix")
    prj.write_input()
    ogs_args = f"-m {mesh_path} -o {temp_path} -s {script_path}"
    prj.run_model(write_logs=False, args=ogs_args)
    sim_results += [temp_path / (prefix.format(dt) + "_domain.xdmf")]
for sim_result, dt in zip(sim_results, time_step_sizes, strict=False):
    ms = ot.MeshSeries(sim_result, time_unit="yrs")
    max_T = ot.variables.temperature.max.transform(ms)
    ax1.plot(ms.timevalues, max_T, lw=1.5, label=f"{dt=}")
    edges = np.append(0, ms.timevalues)
ax1.set(ylabel="max T / °C")
ax2.set(xlabel="time / yrs", ylabel="heat / kW")
ax1.legend()
ax2.legend()
plot convergence study nuclear decay
report_name = temp_path / "report.ipynb"
    output_name=report_name,
    mesh_paths=sim_results,
    timevalue=30 * sec_per_yr,
    variable_name="temperature",
    refinement_ratio=2.0,
report
    timevalue=150 * sec_per_yr,
report
ms = [ot.MeshSeries(sim_result) for sim_result in sim_results]
    ms, ot.variables.temperature, units=["s", "yrs"]
  0%|          | 0/7 [00:00<?, ?it/s]
 43%|████▎     | 3/7 [00:00<00:00, 20.15it/s]
 86%|████████▌ | 6/7 [00:00<00:00, 19.31it/s]
100%|██████████| 7/7 [00:00<00:00, 19.31it/s]
Looking at the errors, we see a higher error right at the beginning. This is likely due to the more dynamic behavior at the beginning.
Total running time of the script: (0 minutes 51.776 seconds)
