Workflow with Feflowlib: Component-transport model - conversion, simulation, postprocessing#
In this example we show how a simple mass transport FEFLOW model can be converted to a pyvista.UnstructuredGrid and then be simulated in OGS with the component transport process.
  1. Necessary imports
import tempfile
)  # fmt: skip
# values of 0.
ot.plot.contourf(clipped_mesh, concentration)
plot D feflowlib CT simulation
<Figure size 1099.71x1080 with 2 Axes>
  1. Setup a prj-file to run a OGS-simulation.
time_steps = list(zip([10] * 8, [8.64 * 10**i for i in range(8)], strict=False))
feflow_model.save()
<OpenGeoSysProject>
    <meshes>
        <mesh>2D_CT_model.vtu</mesh>
        <mesh>single_species_P_BC_MASS.vtu</mesh>
    </meshes>
    <processes>
        <process>
            <name>CT</name>
            <secondary_variables>
            </secondary_variables>
            <process_variables>
                <pressure>HEAD_OGS</pressure>
                <concentration>single_species</concentration>
            </process_variables>
        </process>
    </processes>
    <media>
        <medium id="0">
            <phases>
                <phase>
                    <type>AqueousLiquid</type>
                    <properties>
                        <property>
                            <name>viscosity</name>
                            <type>Constant</type>
                            <value>1</value>
                        </property>
                        <property>
                            <name>density</name>
                            <value>1</value>
                        </property>
                    </properties>
                    <components>
                        <component>
                            <name>single_species</name>
                            <properties>
                                <property>
                                    <name>decay_rate</name>
                                    <value>0.0</value>
                                </property>
                                <property>
                                    <name>pore_diffusion</name>
                                    <value>3.5999998241701783e-10</value>
                                </property>
                                <property>
                                    <value>16441.72737282367</value>
                                </property>
                            </properties>
                        </component>
                    </components>
                </phase>
            </phases>
            <properties>
                <property>
                    <name>porosity</name>
                    <value>0.10999999940395355</value>
                </property>
                <property>
                    <name>longitudinal_dispersivity</name>
                    <value>0.0</value>
                </property>
                <property>
                    <name>transversal_dispersivity</name>
                    <value>0.0</value>
                </property>
                <property>
                    <name>permeability</name>
                </property>
            </properties>
        </medium>
    </media>
    <time_loop>
        <processes>
            <process ref="CT">
                <convergence_criterion>
                    <type>DeltaX</type>
                    <norm_type>NORM2</norm_type>
                    <reltol>1e-6</reltol>
                </convergence_criterion>
                <time_discretization>
                    <type>BackwardEuler</type>
                </time_discretization>
                <time_stepping>
                    <t_initial>0</t_initial>
                    <t_end>48384000</t_end>
                    <timesteps>
                        <pair>
                            <repeat>10</repeat>
                            <delta_t>8.64</delta_t>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                            <delta_t>86.4</delta_t>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                            <delta_t>864.0</delta_t>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                            <delta_t>8640.0</delta_t>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                            <delta_t>86400.0</delta_t>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                            <delta_t>864000.0</delta_t>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                            <delta_t>8640000.0</delta_t>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                            <delta_t>86400000.0</delta_t>
                        </pair>
                    </timesteps>
                </time_stepping>
            </process>
            <process ref="CT">
                    <type>DeltaX</type>
                <time_stepping>
                    <timesteps>
                        <pair>
                            <repeat>10</repeat>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                        </pair>
                        <pair>
                            <repeat>10</repeat>
                        </pair>
                    </timesteps>
                </time_stepping>
            </process>
        </processes>
        <output>
            <type>VTK</type>
            <prefix>/tmp/tmpd072xda0feflow_test_simulation/2D_CT_model</prefix>
            <timesteps>
                <pair>
                    <repeat>1</repeat>
                    <each_steps>1</each_steps>
                </pair>
            </timesteps>
            <variables>
                <variable>single_species</variable>
                <variable>HEAD_OGS</variable>
            </variables>
            <fixed_output_times>48384000</fixed_output_times>
        </output>
        <global_process_coupling>
            <max_iter>1</max_iter>
            <convergence_criteria>
                    <type>DeltaX</type>
                    <reltol>1e-10</reltol>
                    <type>DeltaX</type>
            </convergence_criteria>
        </global_process_coupling>
    </time_loop>
    <parameters>
        <parameter>
            <name>C0</name>
            <value>0</value>
        </parameter>
        <parameter>
            <name>p0</name>
            <value>0</value>
        </parameter>
        <parameter>
            <name>single_species_P_BC_MASS</name>
            <type>MeshNode</type>
            <mesh>single_species_P_BC_MASS</mesh>
            <field_name>single_species_P_BC_MASS</field_name>
        </parameter>
    </parameters>
    <process_variables>
        <process_variable>
            <components>1</components>
            <order>1</order>
            <initial_condition>C0</initial_condition>
            <boundary_conditions>
                <boundary_condition>
                    <type>Dirichlet</type>
                    <parameter>single_species_P_BC_MASS</parameter>
                </boundary_condition>
            </boundary_conditions>
        </process_variable>
        <process_variable>
            <name>HEAD_OGS</name>
            <order>1</order>
        </process_variable>
    <nonlinear_solvers>
        <nonlinear_solver>
            <name>basic_picard</name>
            <type>Picard</type>
            <max_iter>100</max_iter>
        </nonlinear_solver>
    </nonlinear_solvers>
    <linear_solvers>
        <linear_solver>
            <lis>-i cg -p jacobi -tol 1e-10 -maxiter 100000</lis>
            <eigen>
                <solver_type>CG</solver_type>
                <error_tolerance>1e-10</error_tolerance>
            </eigen>
        </linear_solver>
    </linear_solvers>
</OpenGeoSysProject>
  1. Run the model.
feflow_model.run()
4. Read the last timestep and plot the results along a line on the upper edge of the mesh parallel to the x-axis.
    label = ["OGS", "FEFLOW"][i]
    ot.plot.line(
  1. Concentration difference plotted on the mesh.
diff = ot.mesh.difference(feflow_model.mesh, ogs_sim_res, concentration)
5.1 Concentration difference plotted along a line.
fig = ot.plot.line(
Total running time of the script: (0 minutes 4.131 seconds)
