Analyzing integration point data#
This examples shall demonstrate how we can better visualize integration point data (raw data used in OGS’s equation system assembly without output related artefacts), by tessellating elements in such a way that each integration point is represented by one subsection of a cell.
For brevity of this example we wrap the entire workflow from meshing and simulation to plotting in a parameterized function. The main function of importance is to_ip_mesh(). We will use this function to show the tessellated visualization of the integration point data for different element and integration point orders and element types. Note, you can also tessellate an entire MeshSeries via ip_tesselated()
ot.plot.setup.dpi = 75
def simulate_and_plot(elem_order: int, quads: bool, intpt_order: int):
    meshes = ot.Meshes.from_gmsh(
        ot.gmsh_tools.rect(
            lengths=1,
            n_edge_cells=6,
            structured_grid=quads,
            order=elem_order,
        log=False,
    prj = ot.Project(
        input_file=examples.prj_mechanics,
    ).copy()
    prj.replace_text(intpt_order, xpath=".//integration_order")
    model = ot.Model(prj, meshes)
    sim = model.run()
    mesh = sim.meshseries.mesh(-1)
    int_pts = ot.mesh.to_ip_point_cloud(mesh)
    ip_mesh = ot.mesh.to_ip_mesh(mesh)
    fig = ot.plot.contourf(mesh, ot.variables.stress)
    fig.axes[0].scatter(
        int_pts.points[:, 0], int_pts.points[:, 1], color="k", s=10
    fig = ot.plot.contourf(ip_mesh, sigma_ip)
Triangles with increasing integration point order#
Why does the stress not change with the integration point order?
In linear triangular finite elements, the shape functions used to interpolate displacements are linear functions of the coordinates. As this is a linear elastic example, the displacements are linear. The strain, which is obtained by differentiating the displacement, will thus be constant throughout the element. The stress, which is related to the strain through a constitutive relationship will also be constant throughout the element. Thus, the stress is not affected by the integration point order.
simulate_and_plot(elem_order=1, quads=False, intpt_order=2)
  • plot ipdata
  • plot ipdata
simulate_and_plot(elem_order=1, quads=False, intpt_order=3)
  • plot ipdata
  • plot ipdata
simulate_and_plot(elem_order=1, quads=False, intpt_order=4)
  • plot ipdata
  • plot ipdata
Quadratic triangles#
simulate_and_plot(elem_order=2, quads=False, intpt_order=4)
  • plot ipdata
  • plot ipdata
Quadrilaterals with increasing integration point order#
Why does the stress change here?
In contrast to triangular elements, quadrilateral elements use bilinear shape functions. Thus, the differentiation of the displacement leads to bilinear strain. The stress in turn is bilinear as well and can change within the elements. The number of integration points consequently affects the resulting stress field.
simulate_and_plot(elem_order=1, quads=True, intpt_order=2)
  • plot ipdata
  • plot ipdata
simulate_and_plot(elem_order=1, quads=True, intpt_order=3)
  • plot ipdata
  • plot ipdata
simulate_and_plot(elem_order=1, quads=True, intpt_order=4)
  • plot ipdata
  • plot ipdata
Quadratic quadrilateral#
simulate_and_plot(elem_order=2, quads=True, intpt_order=4)
  • plot ipdata
  • plot ipdata
Total running time of the script: (0 minutes 6.166 seconds)
