Interactive Mesh manipulation (OGSTools - Integrated)#
We demonstrate how to access and modify in situ meshes during an OpenGeoSys simulation.
Key features in this tutorial:
  • Inspect mesh data via standard PyVista functions
  • Dynamically modify point/cell properties (e.g., boundary conditions)
  • React to simulation progress or state in an adaptive simulation loop
This tutorial builds on the Run a simulation - Step by step. For a lower-level control, see Interactive Mesh manipulation (Native interface).
Imports and definitions#
from time import sleep  # For simulation pause / interrupt
Select a Project#
We will start with a simple liquid flow project.
model.execution.interactive = True
Read and write in situ meshes#
We will work with these functions:
This example demonstrates an adaptive simulation loop:
  1. The simulation is monitored for steady-state convergence
  2. Boundary conditions are dynamically adjusted during runtime
sim_c = model.controller()
domain_mesh = sim_c.mesh("domain", ["pressure"])
# Let us store the mesh of a time step to compare it later
previous_domain_mesh_pressure = domain_mesh.point_data["pressure"]
domain_mesh_pressure = previous_domain_mesh_pressure
# Later, we will dynamically modify the left boundary mesh
left_mesh = sim_c.mesh("left", ["pressure"])
steady_state_threshold = 0.1 * len(previous_domain_mesh_pressure)  # constant
delta = steady_state_threshold + 1e-10  # to be computed for each time step
Main simulation loop#
The simulation is advanced step-by-step until either:
  • The simulation reaches the defined end time, or
  • The user interrupts execution (Ctrl+C or Stop the Jupyter cell)
while (
    sim_c.current_time < sim_c.end_time
    and not sim_c.is_interrupted
    # any other stopping condition based on the mesh, log, ...
    # e.g. # `delta > steady_state_threshold``
    previous_domain_mesh_pressure = domain_mesh.point_data["pressure"].copy()
    sim_c.execute_time_step()
    sleep(0.01)  # Must have, if you want to pause the simulation
    # --------------- until here minimal loop -------------------------------
    # Example for an In-loop condition
    # 1. Check, if a steady state is reached
    # 2. Change a boundary condition
    delta = np.max(
        np.absolute(
            domain_mesh.point_data["pressure"] - previous_domain_mesh_pressure
    if delta < steady_state_threshold:
        print(
            "The steady state condition is reached. Now a new boundary condition is applied."
        # [:] Is important! Otherwise you would assign a new numpy array to pressure (which would write into the in situ mesh)
        left_mesh.point_data["pressure"][:] = np.full(left_mesh.n_points, 3.1e7)
    # else: we keep the boundary conditions constant
# This simulation reaches the steady state condition twice
# 1st with left boundary pressure at 2.9e7 Pa, 2nd: 3.1e7 Pa
Intermediate plot#
If the simulation is paused or interrupted, you can inspect the current state of the mesh. You are free to adapt the mesh and continue the simulation as shown in while loop above. Let us just plot the pressure field.
fig = ot.plot.contourf(domain_mesh, "pressure")
plot 200 ogs interactive meshes from simulator
Continue the (“paused”) simulation#
# Or run over multiple steps (see while loop above) until end_time
# Run closes the simulation (no more access via SimulationController).
sim = sim_c.run()
Visualization#
# We visualize how the dynamically updated boundary conditions affected the pressure field.
# Changes in boundary conditions can be clearly observed.
ms = sim.meshseries
# Time slice over x
ms_probe = ms.probe(points, "pressure")
  0%|          | 0/11 [00:00<?, ?it/s]
100%|██████████| 11/11 [00:00<00:00, 819.71it/s]
Note: Alternatively, for boundary conditions only (no interaction), have a look at our guide about Defining boundary conditions with Python.
Total running time of the script: (0 minutes 0.721 seconds)
