Aggregation of Meshseries Data#
In this example we show how to aggregate data in a model over all timesteps as well as plot differences between to timesteps. For this purpose we use a component transport example from the ogs benchmark gallery (https://www.opengeosys.org/stable/docs/benchmarks/hydro-component/elder_jupyter/).
mesh_series = examples.load_meshseries_CT_2D_XDMF().scale(time="a")
You aggregate the data in MeshSeries over all timesteps given some
aggregation function, e.g. np.min, np.max, np.var
(see: aggregate_temporal()).
The following code gets the maximum saturation for each point in the mesh over
all timesteps and plots it. Note: the data in the returned mesh has a suffix
equal to the aggregation functions name. The plot function will find the
correct data anyway if given the original variable
Due to numerical oscillations, this dataset contains a few cells with
slightly unphysical saturation (below 0% or above 100%). We clip the
colorbar at vmin=0, vmax=100 to avoid these values dominating the
plotted range.
It is also possible to plot the time when the minimum or maximum occurs. However, here we have to use a new variable for the plot to handle the units correctly:
Likewise we can calculate and visualize the variance of the saturation:
Difference between the last and the first timestep:
It’s also possible to aggregate the data per timestep to return a timeseries of e.g. the max or mean value of a variable in the entire domain.
mean_satuarion_array = mesh_series.aggregate_spatial(saturation, np.mean)
Instead of calculating the array itself, you can also plot it directly by
using methods of the Variable which correspond to the equally named
numpy-functions. The following are available:
min, max, mean, median, sum, std, var.
fig = mesh_series.plot_line(saturation.std)
Total running time of the script: (0 minutes 3.038 seconds)
