Creating meshes from pyvista surfaces#
For this example we create meshes from pyvista surfaces. See other examples for different meshing algorithms.
from shutil import which
from ogstools.mesh import create
# Tetgen is an optional, external (non-pip) requirement - see the note in
# `docs/user-guide/third-party.md` for supported versions/platforms.
tetgen_present = which("tetgen") is not None
if tetgen_present:
bounds = (-200, 210, -200, 210)
args = {"bound2D": bounds, "amplitude": 100, "spread": 100, "n": 40}
gaussians = [
create.Gaussian2D(**args, height_offset=h) for h in [0, -100, -200]
surfaces = [create.Surface(g, mat_id) for mat_id, g in enumerate(gaussians)]
layers = [create.Layer(sf1, sf2) for sf1, sf2 in pairwise(surfaces)]
ls = create.LayerSet(layers)
mesh = ls.to_region_tetrahedron(40).mesh
mesh = None
Visualize the prism mesh
if tetgen_present:
plotter = ot.plot.contourf(mesh, ot.variables.material_id)
Total running time of the script: (0 minutes 0.361 seconds)
