Run a simulation - Step by step#
With interactive execution, OpenGeoSys provides a Python interface that lets you advance a simulation one step at a time, inspect intermediate results, and react before continuing. This mechanism underlies what we mean by Co-simulation: the simulation can exchange information with external analyses or tools during runtime—for example, by dynamically adjusting boundary conditions. In this guide, we will show how to:
Step-by-step simulation control
Inspect simulation status and intermediate results
Prepare for mesh manipulation examples - Interactive Mesh manipulation (OGSTools - Integrated). - Interactive Mesh manipulation (Native interface).
Imports and definitions#
from ogs import OGSMesh
Select a Project#
We will start with a simple liquid flow example and set the OGS execution to interactive.
model.execution.interactive = True
Initialize the simulation and first step#
Use the same arguments as when calling OGS from command line, a list of possible argument are documented under https://www.opengeosys.org/stable/docs/userguide/basics/cli-arguments/
By constructing a SimulationController object we start OpenGeoSys and it (only!) runs time step 0.
simc_1 = model.controller()
print(f"The current simulation time is: {simc_1.current_time} s.")
print(f"The end time defined is: {simc_1.end_time} s.")
The current simulation time is: 0.0 s.
The end time defined is: 100.0 s.
Advance the simulation by a one step#
status = simc_1.execute_time_step()
The current simulation time is: 10.0 s.
Basic simulation loop#
The simulation runs step-by-step until a user specified condition is met. This further allows you to manipulate data arrays associated with the mesh or adapt the logic inside the loop.
while (
# Here, the condition is when simulation reaches the end time:
simc_1.current_time
< simc_1.end_time
# Add here your specific code with mesh manipulation:
my_mesh: OGSMesh = simc_1.mesh("domain")
sim = simc_1.run()
print(sim)
Simulation id: 20260903_083746_689429
(not saved (planned: file:///tmp/ogstools_root/Simulation/20260903_083746_689429))
Model: saved to file:///tmp/ogstools_root/Model/20260903_083746_342765
Result: saved to file:///tmp/ogstools_root/Result/20260903_083746_432544
Log file: file:///tmp/ogstools_root/Result/20260903_083746_432544/log.txt
MeshSeries: file:///tmp/ogstools_root/Result/20260903_083746_432544/LiquidFlow_Simple.pvd
Status: completed successfully (results available)
Advance examples with mesh manipulation#
Manipulate the mesh with either
Total running time of the script: (0 minutes 0.395 seconds)
