This example demonstrates how to create a Borehole Heat Exchanger (BHE) mesh.
from shapely import Polygon
from ogstools.meshes.gmsh_BHE import BHE, Groundwater, gen_bhe_mesh
Introduction#
This example shows the general usage of ogstools.meshes.gmsh_BHE.gen_bhe_mesh() and how some of
the parameters will effect the mesh. This section demonstrates the mesh
generation with only three soil layers, groundwater flow in one layer
and three BHE’s. However, this tool provides multiple soil layers,
groundwater flow in multiple layers and multiple BHE’s. The mesh sizes
provides good initial values for the most Heat-Transport-BHE simulations
in OGS. They can also be set by the user, to customize the mesh.
Feel free to try it out!
Create a simple prism mesh#
Generate a customizable prism BHE mesh:
bhe_meshes = gen_bhe_mesh(
model_area=Polygon.from_bounds(xmin=0, ymin=0, xmax=150, ymax=100),
layer=[50, 50, 50],
groundwater=Groundwater(
begin=-30,
isolation_layer_id=1,
upstream=(179, 181),
downstream=(359, 1),
BHE_Array=[
refinement_area=Polygon.from_bounds(xmin=40, ymin=30, xmax=60, ymax=70),
meshing_type="prism",
meshname="bhe_prism",
Load the domain mesh and all submeshes, extract the BHE lines and visualize it all:
def load_and_plot(bhe_meshes: ot.Meshes):
bhe_line = bhe_meshes.domain.extract_cells_by_type(pv.CellType.LINE)
offsets = [(0, 0, 10), (0, 0, -10), (10, 0, 0), (-10, 0, 0)]
plotter = ot.plot.contourf(
bhe_meshes.domain.clip("x", origin=bhe_line.center, crinkle=True),
ot.variables.material_id,
plotter.add_mesh(bhe_meshes.domain, style="wireframe", color="grey")
plotter.add_mesh(bhe_line, color="r", line_width=3)
for submesh, offset in zip(
bhe_meshes.subdomains.values(), offsets, strict=True
plotter.add_mesh(
submesh.translate(offset), show_edges=True, color="lightgrey"
load_and_plot(bhe_meshes)
Create a simple structured mesh#
Generate a customizable structured BHE mesh:
layer=[50, 50, 50],
begin=-30,
BHE_Array=[
meshing_type="structured",
meshname="bhe_prism_2",
Load the domain mesh and all submeshes as well as extract the BHE lines:
Create an advanced structured mesh#
Generate a customizable structured BHE mesh with advanced mesh sizing options (using gmsh). By adding additional points to the model_area, the subdivison of the surface by the structured mesh algorithm is controlled. To understand the specific behaviour of every mesh parameter, test each one after another.
# add additional points for better subsidivision of the surface by structured algorithm
# compare with previous example, to see the difference
model_area=Polygon(
(0.0, 0.0),
(40.0, 0.0),
(60.0, 0.0),
(150.0, 0.0),
(150.0, 100.0),
(60.0, 100.0),
(40.0, 100.0),
(0.0, 100.0),
layer=[50, 50, 50],
begin=-30,
BHE_Array=[
BHE(50, 40, -1, -60, 0.076),
BHE(50, 50, -1, -60, 0.076),
BHE(50, 60, -1, -60, 0.076),
target_z_size_coarse=10, # default value 7.5
target_z_size_fine=2, # default value 1.5
n_refinement_layers=1, # default value 2
propagation=1.2, # default value 1.1
inner_mesh_size=8, # default value 5
outer_mesh_size=12, # default value 10
meshname="bhe_structured",
Accessing simulated BHE temperatures#
BHE simulation results store temperature per pipe instead of as a single
vector. Which component names exist depends on the BHE type - a single
U-tube (1U) has one pipe loop (in, out, grout1, grout2),
while a double U-tube (2U) has two independent loops in the same
borehole (in1/in2, out1/out2, grout1..``grout4``).
Components_BHE
(e.g. ot.variables.temperature_BHE) knows this per-type layout.
For a mesh with several boreholes, indexing takes a second, separate
argument: the BHE number. E.g. in the mesh below, BHE 1 and 3 are 1U
and BHE 2 is 2U. We probe the inflow temperature at the top of each
borehole over time:
mesh_series = examples.load_meshseries_BHEs_3D("full", ".pvd")
bhe_tops = [(-6.0, 25.0, -27.0), (0.0, 25.0, -27.0), (6.0, 25.0, -27.0)]
mesh_series.probe_values(bhe_tops[0], ot.variables.temperature_BHE[1, "in"])
mesh_series.probe_values(bhe_tops[1], ot.variables.temperature_BHE[2, "in1"])
mesh_series.probe_values(bhe_tops[1], ot.variables.temperature_BHE[2, "in2"])
0%| | 0/2 [00:00<?, ?it/s]
100%|██████████| 2/2 [00:00<00:00, 453.41it/s]
array([21.85 , 22.10904858])
Total running time of the script: (0 minutes 9.330 seconds)
