Spatial refinement - steady state diffusion#
tmp_path = ot.definitions.temp_dir("steady_state_diffusion", "examples")
report_name = str(tmp_path / "report.ipynb")
The meshes and their boundaries are generated easily via gmsh and
Meshes. from_gmsh().
Then we run the different simulations with increasingly fine spatial
discretization via ogs6py and store the results for the convergence study.
refinements = 6
simulations_control = []
meshes = ot.Meshes.from_gmsh(
ot.gmsh_tools.rect(n_edge_cells=n_edge_cells, structured_grid=True),
log=False,
prj = ot.Project(input_file=examples.prj_steady_state_diffusion).copy(
tmp_path / f"cells_{n_edge_cells}"
prj.replace_text(prefix, ".//prefix")
model = ot.Model(prj, meshes)
sim_c = model.controller()
simulations_control.append(sim_c)
simulations = [sim.run() for sim in simulations_control]
analytical_solution_path = tmp_path / "analytical_solution.vtu"
sim_last: ot.Simulation = simulations[-1]
solution = examples.anasol.diffusion_head_analytical(
simulations[-1].meshseries[0]
analytical_solution_path = ot.mesh.save(solution)
result_paths = [sim.meshseries_file for sim in simulations]
output_name=report_name,
mesh_paths=result_paths,
timevalue=1,
refinement_ratio=2.0,
Darcy velocity convergence#
variable_name="velocity",
timevalue=1,
Total running time of the script: (0 minutes 17.295 seconds)
