Spatial & temporal refinement - nuclear decay#
ogstools.physics.nuclearwasteheat model.
from ogstools import examples, physics, studies, workflow
temp_path = ot.definitions.temp_dir("nuclear_decay", "examples")
Let’s run the different simulations with increasingly fine spatial and
temporal discretization via ogs6py. The mesh and its boundaries are generated
easily via gmsh and Meshes. from_gmsh().
First some definitions:
n_refinements = 4
prefix = "stepsize_{0}"
sim_results = []
msh_path = temp_path / "rect.msh"
script_path = examples.pybc_nuclear_decay.parent
Now the actual simulations:
for dt, n_cells in zip(time_step_sizes, edge_cells, strict=False):
ot.gmsh_tools.rect(
lengths=100.0, n_edge_cells=(n_cells, 1), out_name=msh_path
meshes = ot.Meshes.from_gmsh(msh_path, log=False)
mesh_path = temp_path / f"dt_{dt}_n_cells_{n_cells}"
mesh_path.mkdir(parents=True, exist_ok=True)
meshes.save(mesh_path)
prj = ot.Project(output_file=temp_path / "default.prj", input_file=prj_path)
prj.replace_text(str(dt * sec_per_yr), ".//delta_t")
prj.replace_text(prefix.format(dt), ".//prefix")
prj.write_input()
ogs_args = f"-m {mesh_path} -o {temp_path} -s {script_path}"
prj.run_model(write_logs=False, args=ogs_args)
sim_results += [temp_path / (prefix.format(dt) + "_domain.xdmf")]
for sim_result, dt in zip(sim_results, time_step_sizes, strict=False):
ms = ot.MeshSeries(sim_result, time_unit="yrs")
max_T = ot.variables.temperature.max.transform(ms)
ax1.plot(ms.timevalues, max_T, lw=1.5, label=f"{dt=}")
edges = np.append(0, ms.timevalues)
ax1.set(ylabel="max T / °C")
ax2.set(xlabel="time / yrs", ylabel="heat / kW")
ax1.legend()
ax2.legend()
report_name = temp_path / "report.ipynb"
output_name=report_name,
mesh_paths=sim_results,
timevalue=30 * sec_per_yr,
variable_name="temperature",
refinement_ratio=2.0,
timevalue=150 * sec_per_yr,
ms = [ot.MeshSeries(sim_result) for sim_result in sim_results]
ms, ot.variables.temperature, units=["s", "yrs"]
0%| | 0/7 [00:00<?, ?it/s]
43%|████▎ | 3/7 [00:00<00:00, 26.96it/s]
86%|████████▌ | 6/7 [00:00<00:00, 25.59it/s]
100%|██████████| 7/7 [00:00<00:00, 25.61it/s]
Looking at the errors, we see a higher error right at the beginning. This is likely due to the more dynamic behavior at the beginning.
Total running time of the script: (0 minutes 29.382 seconds)
